So I told my parts guy I needed a Ford 8.8 rear end out of a 96 to 2001 Ford Explorer and this is what he brought me. The left side is 17 in the right side is 20. Shouldn't the knuckle be centered for it to be a good swap in a 2000 TJ?
How in the world did you get the vibration out. My rear yoke is 16.1* and DS is 18.1* but can’t get it out bc of the offset I’m guessing. Wonder if I can unbolt the motor and tranny mount to maybe crank it a bit straighter?? Vibration is at 65mph+Like Jerry said, they all are. Mine is offset and I drove around on the stock driveshaft for a year without vibration or excessive wear. I know the fabricator did spend quite a bit of time dialing in the right pinion angle to get rid of the vibration it started with though. After I got my SYE and new driveshaft just a month ago its still vibration free so make sure you are prepared to put in some tuning time
Sent from my SM-N950U using Tapatalk
Did you install an SYE, DC shaft, and adjustable control arms?How in the world did you get the vibration out. My rear yoke is 16.1* and DS is 18.1* but can’t get it out bc of the offset I’m guessing. Wonder if I can unbolt the motor and tranny mount to maybe crank it a bit straighter?? Vibration is at 65mph+
Have been very happy with my 8.8 swap over the years. I'd recommend the c-clip eliminator kit from yukon but it is pricey.
There are two things Jerry does not like, Ford 8.8 and High Lift jacks. There should be a warning for everyone here that if you mention either one, Jerry is going to let you know he does not like either one.![]()
And we all know what they said about "OPINIONS". And yes I have some also and a lot of them stink too.
I have to poke fun, every time 8.8 shows up here, here comes Jerry!![]()
You should try bringing up Long Arm suspension lifts.... Then you get to see a picture of Jerry hung up on a rock too.
