Hey guys, I am don't know much about steering stabilizers and I think I need it on my Jeep Tj. I am putting a 2 inch lift with a 1 inch body lift and am going to run 33s. Can you guys help me figure out what I need?
The steering stabilizer (more accurately known as the steering damper) requires nothing special, the least expensive one you find will be fine. Stick with a stock hydraulic like a Monroe, Rancho, etc.
Thank you. I did more research and realized that expensive and cheap steering dampers are almost no different in ride quality. Thank you everyone for your help.
Yep, your research is spot on. You won't notice any difference at all between the steering damper I linked to and something much more expensive. Though I will say some of the more expensive ones actually make it harder to turn the steering wheel, which isn't a good thing.
