4.27 or 4.30 gearing is also an option for Dana 44 and 8.8 differentials only and might be suitable for that tire and transmission. If you have a front Dana 30 that ratio is not currently available to my knowledge
Yeah I just installed 4.88 not too long ago so not ready to regear4.27 or 4.30 gearing is also an option for Dana 44 and 8.8 differentials only and might be suitable for that tire and transmission. If you have a front Dana 30 that ratio is not currently available to my knowledge
So is 3100 rpms safe to run in a 4.0 engine??I have a 32rh, 4.88 gears and 35" tires. 65 mph is around 3100 rpms. I plan on regearing to 4.56 soon so 70 can be 3100 rpms.
4.10 is generally the recommended ratio for 33s with the 32rh. a higher ratio would probably be better.4.10 is about right for 35s
35" MTR
32rh/33.875"/3.07=2284rpm @ 75mph
32rh/33.875"/3.73=2775rpm @ 75mph
32rh/33.875"/4.10=3050rpm @ 75mph
32rh/33.875"/4.56=3392rpm @ 75mph
32rh/33.875"/4.88=3630rpm @ 75mph
Amen. I was all over it as well, even talked to SilverStar. My 03 is a manual...my 06 is an auto. Thankfully our Rubi 4:1 transfer cases make the manual very workable, but the auto allows you to concentrate on the obstacle entirely.If an auto swap wasn't such a can of worms given the current options, I would gladly make the change.
Thanks Jerry. I really want to get it even though it has to be overhauled. Id love to try it .I did the exact same conversion to a 32RH with my previous TJ that had 35's and 4.88 gears for its original 5-speed manual. It was AWESOME, all I did differently afterward was slow my highway speeds down a tad from 65-70 to 55-65 in the slower lanes with occasional runs at 65-70 to keep up with traffic in the slow lane. The rpms are absolutely not even close to an issue for the 4.0 so don't let the rpms alone dictate your decision.
If your TJ is primarily a highway cruiser I might not but if it's primarily for fun with occasional highway trips I wouldn't hesitate. Slowing my cruising speed down a tad was no big deal and I often took 250-500 mile trips in it.
What years were they, and what all had to be done ...and did everything work, gauges etc. I would imagine it was great. I’d rather have an auto that winds one a tad tight than the lazy 42LRE if i swapped one in anyway.I did the exact same conversion to a 32RH with my previous TJ that had 35's and 4.88 gears for its original 5-speed manual. It was AWESOME, all I did differently afterward was slow my highway speeds down a tad from 65-70 to 55-65 in the slower lanes with occasional runs at 65-70 to keep up with traffic in the slow lane. The rpms are absolutely not even close to an issue for the 4.0 so don't let the rpms alone dictate your decision.
I nearly sold my 03 to get one I found, but is was so badly built and had a snorkel cut into it, it just wasn’t my type TJ and the cost to rebuild made it prohibitive.
I eventually ran into a cool, very very sound, mostly stock Rubi with an auto and 78.000 and wheel it the most.
All that to say I don’t know what I was thinking buying a manual, autos were rare and on the tree, sorts looked down at in the CJ days.
So your telling me 4500 rpms is in the powerband???? ive never run my tj at 4500 rpmsthe powerband at around 4500+ RPM to climb hills and pass with ease.
Im thinking the same thing.Then I'd suggest you try it out.....
I don't suggest your run your 4.0 @ 4.5K rpm's for a long time but it can be done to pass someone or to climb a steep hill. There are always going to be times you will need to back off the skinny pedal but it doesn't hurt your engine to run it up above 4K now and then.
Yup. Peak torque is in the range of 3000-3500 RPM. Peak power is around 4500 RPM.So your telling me 4500 rpms is in the powerband???? ive never run my tj at 4500 rpms
The biggest driveability issue I see with 4.88 and the 32RH is that 2nd gear is not usable at higher freeway speeds. You would be relying on 3rd gear at 3100-3300 RPM to climb hills and pass people as well as to cruise. With 4.10, you can easily downshift at 70-75 mph to 2nd and run right in the powerband at around 4500+ RPM to climb hills and pass with ease.
