The PO of my Jeep had a Fabtech lift installed with a dropped track bar mount. This required drilling the track bar bolt hole out to 3/4" and drilling a 5/8" hole in the side of the mount. I had a spacer welded in to reduce the mounting hole to 5/8 but their is still a big hole in the side. On a recent inspection it appears that a crack may have appeared. I saw that Barnes sells a weld on replacement. Considering where the crack is I was wondering if it would be easier to replace the mount vs trying to repair it?
