Mines ok just wanted to get one just in case, the vid below I think is bad case?Is there a distinguishing awful/obvious noise this will make when it is going bad? I have an 06 and have no clue if mine has ever been replaced
OPDA Squeal - YouTube
When @Zorba says that, I always really get edgy....Finally found an outfit
Keep it up pal, I can start posting pictures!
Thanks fish! Man that sounds horrible, I’ll get one for the shelf and install on the coming weeks. I would like to determine if mine has been replaced. I have done some reading on it.Mines ok just wanted to get one just in case, the vid below I think is bad case?
For me it was just a ticking noise while it was warming up, somewhere betweeen 60 and 80 deg. Once it was warmed up it would stop...Is there a distinguishing awful/obvious noise this will make when it is going bad? I have an 06 and have no clue if mine has ever been replaced
I missed the part where you found the solution....What fixed the tick on start up?For me it was just a ticking noise while it was warming up, somewhere betweeen 60 and 80 deg. Once it was warmed up it would stop...
replacing the OPDA... Mi tick was not at startup. It started ticking when temp reached 50-60 deg, and stopped just before fully warmI missed the part where you found the solution....What fixed the tick on start up?
Ahh, that is "start up" temp in my neck of the woods. Today, my scangauge read 68º at start up. The tick continues till it passes 130º, then smooth and clean. OPDA it is. Thanks!replacing the OPDA... Mi tick was not at startup. It started ticking when temp reached 50-60 deg, and stopped just before fully warm
Got a recording of the tick? I have only ever heard the "laughing monkeys" squeal mentioned like in the vidAhh, that is "start up" temp in my neck of the woods. Today, my scangauge read 68º at start up. The tick continues till it passes 130º, then smooth and clean. OPDA it is. Thanks!
I need to do this. Guy I bought it from “repaired” one of the cables with hardware store parts and it’s stretched out. I assumed the cables were available separately but this looks like the cables come as an assembly. Does this part number replace both sides?replaced broken cable to rear seat tumble. Easy fix.
How do you like the way it works,drives, etc.Antirock installed. Hardest part was getting the plastic bushings Installed. It took a little massaging and a lot of whacking with a 2.5lb sledge.View attachment 216677
https://www.moparpartsgiant.com/par...xtra1=&extra2=&filter=(E=ERH;T=DDD;M=Rubicon)
I haven't taken it for a drive yet. When I do I'll post my thoughts.How do you like the way it works,drives, etc.
