Starting a 32RH Swap
Eddie Greenlee
Mississippi
Hey , well here it is , a 2002 32 RH auto transmission. I’m getting things together in order to do a swap out of my 97 - 5 speed manual trans. I’ve compiled a list of things too get from Jerry and mrblaine. Thought I would post it here and maybe I can keep up with things I have to get.
If he's not dead set on a factory tube. I would just run a lokar setup or after market that fits.
Are the wrangler 32rh tubes/stick hard to locate?
Yes. I’ve found one legitimate one in the last month. The problem is the salvage yards don’t want to separate the tube from the tranny.
English not your first language?
I will soon have an example of what a 32rh dipstick looks like and actually two examples of what what a 32rh dipstick does not look like. I have to put those two to use somehow.
Ok. You may need to run an aftermarket kit. At least that's what I would do. The 32RH dipstick seal is the same as many other Chrysler automatics. There will be something that will work.
Since the factory style tubes are not readily available it seems.
Reactions: Eddie Greenlee
