Alright, when you get it figured out, let me know. I already figured my area out.Some but both of us are fairly new to the area so not super submersed in all of them yet.
Well, for now I'm going to skip the RMS. Thank you, because you always know more than me, so I'm the one learning here from the master mechanic.
I wish I could get the RMS done, it's always messy around the TCase because of oil and now ATF. I'm tired of that crap!
That’s the second time someone has accused me of being a girl on here.I think the first was Jerry Bransford. I have some hand problems though, so I’m the first to admit I don’t have the strongest handshake.
How pissed would you be if the PO did that and you went to replace a half sealI wonder if you can get a solid seal for the 4.0 instead of the half round??
How pissed would you be if the PO did that and you went to replace a half seal![]()
But I might have the biggest Dick! Or I might be the biggest Dick. No matter how you look at it, it’s the same thing.
I got the shifter free of the boot, all sensors and attached electrical detached. Slave cylinder removed, negatively be battery terminal disconnect, starter detached, 2x E12 bolts on top removed. Just need the motivation to go drop the tranny now.
Hope it works. That will be a bit funny if it works easily now.Went back to the FSM, I don’t have the transmission in neutral. For crying out loud. I bet it will slide right out when I shift it into N
I know, but it makes sense, right, it’s engaged as long as it’s not in neutral. We;ll see in the AMHope it works. That will be a bit funny if it works easily now.
Everything looks big in a tiny hand.But I might have the biggest Dick! Or I might be the biggest Dick. No matter how you look at it, it’s the same thing.![]()
You're that far into it, pull it off and have it cut, you'll get much better engagement
Flywheel machining is not recommended. The flywheel
clutch surface is machined to a unique contour
and machining will negate this feature. Minor flywheel
scoring can be cleaned up by hand with 180
grit emery or with surface grinding equipment.
Remove only enough material to reduce scoring
(approximately 0.001 - 0.003 in.).
Did not know that, never seen on in person
