Here is my current key & lock situation which is a mess, but I believe the Jeep was repossessed at one point in its history.
I have one working aftermarket ignition key with SKIS/SKIM.
I have a second aftermarket key cut for the ignition cylinder but it is not programmed to the car or is not a sentry key.
I have full doors from a 2000 Jeep Wrangler and no keys that I purchased from a junk yard since apparently the factory doors weren’t on the Jeep when it was repo’d years ago.
I have a tailgate from a 2006 Jeep Wrangler and a single aftermarket all metal key that I bought since the one one the Jeep had the lock cylinder ripped out and damaged the sheet metal. The lock face measures 1.25”.
Ideally I would like to be able to have the ignition key unlock both doors and the tailgate; however, would also be okay with a second key that worked on both doors and the tailgate.
I have found the following very useful posts
I have the following questions
- Wolf security keying service https://wranglertjforum.com/threads/door-locks-wolf-security-hardware.40338/
- How to identify and program sentry keys https://wranglertjforum.com/threads/skis-skim-sentry-key-programming.16848/
- Where to find parts for lock cylinders https://wranglertjforum.com/threads/finally-fixed-my-stuck-door-lock.45178/#post-783140
- How to rekey lock cylinders https://wranglertjforum.com/threads/how-to-re-key-half-door-lock-cylinders.26338/
- My 1999 TJ had a single key the ignition and all doors. Was this the same in 2004, or was the ignition key separate from the sentry key for the ignition?
- Can I re-key the 2000 door lock cylinders to work with a 2004 key?
- Can I put 2004 door lock cylinders in a 2000 door, or are they bigger in diameter?
- Did the number of tumblers in the lock cylinder change between 2000 and 2004 such that it’s not possible to use a single key for both?
