Yesterday had a great time at Bellmore State Forrest. Two buddies came along, they have JKs but I try not to hold that against them.
To make it easier to swap between 1/2 and full doors, I put on mirror relocation brackets. Gonna give them a try and see if I like them.
Its ok the PBR has worn off now but I woke up this morning with e mail conformation orders for bolts from everywhere!In memory of @Fishtaco , I bought some tow hooks.
Mine doesn't seem noisy enough to need sound deadener, whats causing the noise tires or just bad roads?In preparation of getting ready for Sound Shield sound deadening treatment, I am taking care of some small rust issues on the floorboards.
Before wire wheel on a drill.
I knocked the heavy stuff off.
Once the sound deadener is applied to the floors and lower portion of the firewall, bedrug carpet will be installed. This fix will last for years with the rust treatment, new floor plugs, sound deadener and bedrug. hooray for a quieter jeep!
That and I replaced the clicking rear sway bar end links. Today was a good day to wrench on my jeep. Wrenching, when all goes well is therapeutic!
Angles on the rear motobilt bumper is sick for sure.
Im only running ATs but, Id say a mixture of tires, bad roads and the echo chamber that is the factory hard top. Im hard of hearing already and cant hear the stereo very well. I added sound treatment to the doors already and it made a difference!Mine doesn't seem noisy enough to need sound deadener, whats causing the noise tires or just bad roads?
I just put a set of those on my jeep this week. The fit and finish looked good and they mounted up fine. The only problem I had was the bolt holes were a hair too small. I just used a 1/2" bit in a cordless drill and opened the holes up a bit and it fit great. They're nice and solid when mounted.I like these and I’m not ashamed.
https://www.roughcountry.com/rc-jeep-wheel-to-wheel-nerf-steps-rcj9746.html
