Time to replace that Tough Stuff door vinyl.I replaced the rusting door handles on the outside!View attachment 241408View attachment 241409View attachment 241410View attachment 241411
My doors open so smoothly now!
One is a fog one is a driving light, all additional lights here must be wired to a switch and connected to the high beam, I suppose that's why later export Tj,s didn't have the front Fogs in Australia they are pointless? Its illegal to run fogs without headlights and with no fog present unless the function is factory like my Nissan work 4x4 had, you couldn't turn them off on the Nissan they came on with ignition from factory.Wait your fog lights have to be wired to your high beams by law? Doesn't that defeat the point of the fog lights, because the high beams would be reflecting off the fog and blinding you?
I would like to get some fog lights but the light mounts on my bumper are probably too high for fog lights to be effective since I know they have to be mounted low
How do you get those triangle pieces off?
What he said is correct, two screws on outside of door behind stripping. You can lift them out with the metal piece or pop out the stripping that the window slides into and remove two screws there too.Push the door weather stripping aside and find two Philips head screws. Remove the screws and work it out. Part of the removable seal around the window needs to come out also but that's pretty easy.
I'm assuming @Fishtaco meant to have the fog lights turn off with the high beams. That's how the TJs (at least the 05-06) came stock. You can bend one of the relay tabs to disable this to have full brightness from high beams and fog lights at night. I believe the idea was to reduce the amount of light output for oncoming traffic with both high beams and fog lights.Wait your fog lights have to be wired to your high beams by law? Doesn't that defeat the point of the fog lights, because the high beams would be reflecting off the fog and blinding you?
You have a wiring harness running along there and then up the leg of the "roll cage". Careful when you drill and you should be ok.Keeping with the theme of old worn out greasy Jeep parts, @starkey480 was kind enough to take time out of his Easter sunday for me.
New to me Warn sliders.
A question though, can I run a nutzert into the tub to the right of the "W" cutout ? Mine is an 04 so I cant use the 5th hole ( counting left to right ) because of the change in the seatbelt design. I am not sure if there is anythang under the sheetmetal I could damage by putting a fastener back there.
It’s snowing there and 85 heteFinally double locked and loadedwent camping to test it out on the weekend.
Found a wicked creek/waterfall to play on and me and some buddies cleared the path to a Fire Lookout Tire. 4hrs up, 10min down hahah
Yeah I am done with the cold...at the base of the mountain was about 60-65 degrees. Spring IS comingIt’s snowing there and 85 hete
POR15! Its a converter. Knock off the heavy rust with a wire brush, clean with a wax and grease remover, then apply the converter.Tip, if you're using por15 on a surface that gets sunlight, you need to topcoat it. It'll chalk and fade on you.What did you use to paint the tub? Any other primer or converter over the formerly rusty areas? I'm going to start a sound deadening project soon and I'm collecting as much info as I can
I've never been able to figure out what it was called until you commented that, thanks! Yeah, the ripples have been there since I bought it, been thinking about replacing it but it's such a forgettable thing that I've never gotten around to it.Time to replace that Tough Stuff door vinyl.I see some large ripples.
SEC10 now makes them.I've never been able to figure out what it was called until you commented that, thanks! Yeah, the ripples have been there since I bought it, been thinking about replacing it but it's such a forgettable thing that I've never gotten around to it.
I am still looking for the fender tool protectors but they are not available anymore, I wonder if Sec10 make them?SEC10 now makes them.
https://www.extremeterrain.com/barricade-body-decal-yj-tj-j100712.html
