Received my "anchor point" I'm putting in the back of the garage so I can spool on line in my driveway. I needed to drill a pair of 1/2" holes in it. Well, I learned something new today! My little Harbor Freight drill press really isn't good for much over about 3/8" in heavy steel, although it did fine up to that point. So I broke out "Old Granddad", a huge 1/2" slow speed drill I inherited from my late father. That made short work of this job! Dad bought that drill, a "Thor", for $100 in about 1949, and it wasn't new then. Best I've been able to figure out, it was apparently made in the 30s sometime.
Sounds like Old Thor is cable of giving you some busted knuckle. I have a 1/2 Inch Milwaukee that bust your wrist if you get it stuck.
Installed some G2 axles. Should hopefully fix my seal woes and now have a pretty bulletproof Dana 44.
Deliveries can make or break a weekend plans, there are just so many more yesterdays than tomorrows and deliveries always seem to be tomorrow lol
Boy,you said it,we are retiring in a year and flat towing the Jeep, last may started with a stock Jeep and there is just not enough time to get to all the mods I want to do!
I got mine back from my friend’s shop yesterday. They took care of a whole laundry list for me:
Installed 2 new tires
Mounted spare tire carrier
Adjusted brake shoes and parking brake cable
Installed a new washer pump and nozzles
Inspection
Front brakes
Replaced stabilizer bar end links
Timing belt/water pump
Oil change
Spark plugs
Muffler
Installed my steps
Then when I got her home I installed the mesh sunshade, new soft top and new stereo….
