It would seem for some reason that the hinges / latches that hold the front of the hardtop down to the windshield / header on my TJ aren't pulling down with as much force as they should. I know this because when driving at high speeds you can hear some air getting in through the header seal.
However, when I have my wife slightly unbuckle one of the latches (while going about 60 mph) and then use the handle to pull down on the top, the noise goes away. This leads me to believe that my hinges aren't pulling down with enough force when fully clamped, and therefore the hardtop is not 'sealing' with the header seal well enough.
I looked at the stock hinges and it appears they are not adjustable. However, this got me thinking, does anyone know if any adjustable hinges out there that would replace the stock ones but allow for a certain level of adjustment?
