Here's a look at what the rear body mount isolaters can do for the 6 under the door.
The rear upper is .875". The rear lower about .75". And the bolt head adds another .25".
Under the door, the upper is about 1.25". The lower is about 1.125". And the bolt/washer and another .25".
As Blaine described earlier, just replacing the lower isolaters under the door with the ones used for the rear, along with a recessed flathead bolt, the lower isolater could be raised up an additional 1/2" into the mount.
If the upper piece is used, the entire mount could be raised an additional 1/4".
