Im sure your question was directed at OP. But here in the south (Alabama) having an electric fan with more CFM capabilities is beneficial for A/C performance. It’s a different kind of hot here in the summer, humidity is the killer IMO. Having an electric fan is a go to route for some Jeep/crawlers here that have A/C and are often rolling slow or idling through trails. More CFM on the elctric puller or pusher fan is beneficial and oays dividends on those really hot days.
Like I mentioned its a common swap on the 4.0’s in my area where crawling is so popular.
Not to mention depending on the fan setup, they clean up the engine bay.
Hard to tell but were you asking in a rhetorical question way?
Here in Florida its hot also try crawling on trail or hwy. when its 97 + 100 % humidity the A/c just doesn't cut it . Which since you brought it up I have been working on a cooling mod.
Let me state from beginning my Jeep doesn't not over heat runs right at 210 in summer as many recommend I am just trying this to improve A/c performance.
After doing a lot of research I found jeep had a 7 blade fan and HD clutch for the TJ available at one time. The update was short lived and parts are not currently available
PN: 55037650AA, Fan 7-Blade,
PN: 05066177AA, HD fan clutch
I am not shure why program from Chrysler was discontinued, probably felt wasn't needed since right around time it was discontinued they came out with single core radiator which improved on existing. I do know Tj engine bay gets hot Eg heat sock on injectors etc.
I start looking for alternatives to get a little more air flow on A/C condenser when idling etc.
I found some people were recommending a 9 or 10 blade fan from explorer before they went to electric fan I looked at those however is a plastic blade and could not find any data on blade performance one person stated had converted and worked great even without fan shroud
(don't know why you would run without shroud makes no sense)
I found Derale sold a 18 inch reverse rotation 6 blade steel fan
Pt# 17918 I ordered one and Hayden HD clutch pn#2771
Before removing my old fan I did some testing for comparison
When I received new fan was impressed by quality of part made in USA very nice and looked heavy duty ( I have used Derale trans coolers before consistently have a good product)
In comparison to my 5 blade noticed besides extra blade new fan had less pitch, began to wonder if would make a difference, called Derale while they didn't have fan curve data, they did tell fan me was designed to produce 500 to 750 cfm more then stock
This is my test data before and after using Fluke 922 airflow meter
orginal idle 450 cfm 0.21 static
1200 rpm standing 700 cfm 0.35 static
6 blade idle 635 cfm 0.36 static
1200 rpm 1020 cfm 0.48 static
This project I have been thinking about for a while however never got installed until recently now weather is cooler so will have to wait to produce more data on A/c performance at higher temps etc. this was done first of Nov at 83 degrees
I am hoping by getting more airflow over A/c condenser as to dissipate heat a little faster
