That’s one I plan to grab, but I have up to 6 wks to do it so I’m getting my garage organizedHF makes a great welding cart btw.
New Miller 211 doesn't fit the HF cart width now. I'm still deciding if I add a riser or cut the cart down the middle and add in the extra 1"-1.5" needed for the Miller...I really love my Miller 211. It’s so much easier to weld with than the Lincoln’s I’ve used
That was a short backorder. Congratulations!!!
I got lucky, the local shop had a few in order and those ahead of me in line got substitutes!That was a short backorder. Congratulations!!!
That’s great to hear! I may make a cart my first project.I just got the same a few months back. It's my first welder for my garage. Still have a smile each time I use it!
Get it on 240 and never look backI’m surprised how much 110v can do, this was just to break in the machine and play with settings… other than burning my wood top work bench being a noob and ugly beads I’m so excited for all the projects I just unlocked. The stack on the bench will be shrinking finally!
How does the hitch pin go on to hold the rack?
The LJ has a fairly large opening between the gas tank and rear crossmember (about 5”) where I can access it.How does the hitch pin go on to hold the rack?
I have an older model 211, and absolutely love it!
Good luck on the rack. I tucked my receiver in too, and it's so short, the rack doesn't fit past the spare. I need to run an extension.
Spare tire delete... Got it!It used to not fold up with the old dirtworx, now it does both functions!
