Hey everyone, I am soon to install my york 210 compressor and would like to get ideas for plumbing the lines. If you wouldnt mind posting pics of your setups, that be great. Thanks
Hey Dylan, not sure which setup you have going but ORO has a kit for the TJ. You do want a manifold with a pressure switch that’ll disengage the clutch if the line reaches a certain pressure. You don’t need a regulator as the york puts out about 10cfm continuous duty.Thanks for the pics, much apprieciated. One question, If I were to not run a tank e.g just a discharge line right to an air chuck, do I need a pressure regulator and a pressure release valve? Im not too clear about that
Yes only airing up. I just bought the oro kit. Already have a remanufactured yorkHey Dylan, not sure which setup you have going but ORO has a kit for the TJ. You do want a check valve that’ll disengage the clutch if the line reaches a certain pressure. You don’t need a regulator as the york puts out about 10cfm continuous duty.
this is for airing up only correct? Not lockers?
Awesome you’re good to go thenYes only airing up. I just bought the oro kit. Already have a remanufactured york
Do you have a link to the one you just posted? And I noticed that button to the right of it?Awesome you’re good to go then![]()
Edit: That all came with my York kit. It’s a manifold and 150psi pressure switch. The rocker switch is just a 3 prong on/off switch. The york kit came with a wire harness to wire the pressure switch to the clutch.Do you have a link to the one you just posted? And I noticed that button to the right of it?
Oh ok, i mustve bought a different kit then. Mine comes with the bracket and pulley and hardware, thats itEdit: That all came with my York kit. It’s a manifold and 150psi pressure switch. The rocker switch is just a 3 prong on/off switch. The york kit came with a wire harness to wire the pressure switch to the clutch.
I paid an auto parts recycler $30 for my used York F210, what'd you pay for yours?Yes only airing up. I just bought the oro kit. Already have a remanufactured york
If you are referring to a coalescing filter then yes, that is a good idea...This thread just reminds me that I need to put an oil cooler device on my OBA setup...
No, I am referring to a cooling device. Such as a transmission cooler to cool the air/blow-by. I dont have enough experience with a york, but on my sanden what little oil that is coming out is incredibly hot. So much so that it melted the filter within my coalescing housing. I know @jjvw installed a cooler on his york set up.If you are referring to a coalescing filter then yes, that is a good idea...
Interesting, I never had that problem but I do run several feet of hose before the filter. If you install it on the firewall you should also make sure it's not too close to the exhaust manifold (or shield it) because that shit gets HOT.No, I am referring to a cooling device. Such as a transmission cooler to cool the air/blow-by. I dont have enough experience with a york, but on my sanden what little oil that is coming out is incredibly hot. So much so that it melted the filter within my coalescing housing. I know @jjvw installed a cooler on his york set up.
I paid around $230 from a big rig truckers webiste for a new oneI paid an auto parts recycler $30 for my used York F210, what'd you pay for yours?
I just bought a small power steering cooler to cool the air so it doesnt melt. I did what @jjvw didThis thread just reminds me that I need to put an oil cooler device on my OBA setup...
I got mine from a newer junk yard Grand Cherokee. It lives in between the pump discharge and the manifold. There is quite a bit of temperature difference on either side.I just bought a small power steering cooler to cool the air so it doesnt melt. I did what @jjvw did
