Gfacer
Finished installing a Cherokee (chopped) roof rack on my hard top. Should be good for a few skis or a couple plastic kayaks.
They get drenched during water crossings.
Second the ratcheting wrench.Cool, just ordered one and it'll be here tomorrow.
I watched a video that fumbled around with the wheel well liners. Yeah, I'm going to take mine off completely.
I was able to push the rear liners in enough to not have to remove them.
The bottom two on the back of the front flares.. those are a bitch to get to and ultimately spun on me. Had to grind them down enough that I could push them through and finished with nutserts.
Overall a PITA but not awful.
Sending positive energy your way.Yeah, if I have to replace any nutserts, I'd have to go out and buy a tool for that. Trying to avoid that. Luckily, my TJ has on 74k on it, has been garage kept, has been kept in the South, and from a year of work on it, I haven't had any rust or corrosion issues from stuck bolts.
I put tweeters on my A piier. Double face taped it to the plastic trim. Sound is great
Where do you wire the tweeters in??
I'm running a soundstream picasso nano 5 channel.
Front speakersb(dash) wired to 1&2, soundbar wired to 3&4, bass (in center console) wired to channel 5.
Can I piggy back tweeters on the dash speakers?
I have no rust, but those spun on mine too. I replaced my flares about 18 months ago. Luckily, I had some really long needle nose pliers to hold the nutserts while I removed those bolts on each side.The bottom two on the back of the front flares.. those are a bitch to get to and ultimately spun on me. Had to grind them down enough that I could push them through and finished with nutserts.
I used little vice grips. worked great
Customized the front fender courtesy of a tractor trailer
Looked at it in the sun after a morning ride. Rain coming here until Tuesday.
Oh damn! Glad you're ok. That pic clearly shows who's at fault. Should be an easy insurance transaction.
