Finished up adjustments on the rear today, well almost, still have to tweak the pinion angle a tad.
Got the axle adjusted so no tires rubbing anywhere throughout the entire flex cycle.
Bump stops set and centered as best as tires will allow.
Put it back together. Set on the ground. Rear axle not square to frame. Out by 3/16. Adjusted as needed.
How often do the lowers have to be slightly different lengths?
