I was on my way back from Moab, in the middle of Nebraska, on a Sunday afternoon when the jeep went into limp mode for a random misfire, can't recall the code.Jesus...that is like a grand. How did you know you needed this, any tells other than CELs?
Checked all the plugs at the next exit.
Ran fine on a restart.
Headed back out on I80, hit about 55 and back into limp mode.
After some F'n around and test runs I determined I couldn't exceed 55 or the load would cause a misfire.
Set the cruise and drove the rest of the way home under 55 mph.
Next day I hooked up a blue driver OBD2 dongle and it said I needed a new cat.
I ordered that setup and had it in a couple days.
Once I pulled the exhaust it was clear looking in it the internals of the cat were loose and blocking the exhaust flow.
New cat setup fixed it all.
If you think it's cats the best way to tell is to pull them and take a look. Especially if they now cost over $800. Probably be cheaper to have someone weld in new ones.
