Thanks for the advice.I’d do it to see if it’s an issue with front, back or both. Then I’d address them as necessary.
Yeah, I've followed your case in a number of threads and re-read parts of it on Chris' thread addressing this specific issue yesterday. You're the outlier, of course. Maybe that X spline will help, that was one of @Alex01's suggestions that helped him get vibe free. Thanks also for the offer of the RS 55241's. I can't remember why you ditched those for something else, but I think I'm good now. At least my shock is still working. When I went into the muffler shop they asked me if someone had hit me from behind (when they saw it bashed into the shock body). I said no, of course, I would know that. Then it dawned on me that I had very likely backed into a large rock when wheelin Saturday and that pushed the whole exhaust forward, knocking it off the hangers and bashing it into the shock. What a day. With it chopped off I will never have that problem again.I've read situations where the vibes only occurred when both drive shafts were attached. Remove one or the other and vibes went away. Not saying that is your situation, but that's what I did when I was diagnosing my vibes. I removed the front out of the equation. And just to make sure to myself, I also remove the rear shaft and ran in 4wd to verify. My vibes are coming from the rear shaft, or the combination of both shafts making the connection to the t-case. I have also entertained the idea of the t-case skid creating issues, which is why I went with a thicker Barnes skid. Adding a MML (Motor Mount Lift) netted the most positive change for my Jeep to date. As a last ditch effort, I'm trying one of Tom's drive shafts with the X spline design and triple checked balance.
