I ordered a welder. It took me all day to decide, and I've been thinking about it for a month. 20% off. I guess I am 'all in' now and will 'try' to step up to the big leagues.
A local guy just got that one and has so far reported that it's pretty great. Can't wait to see what projects it unlocks for you and the twins!
Kind of? I'd be stoked!
Kind of only because I’m nervous. Don’t want to blow myself up or something. I’m sure I’m blowing it all out of proportion.
How do you like your CO2 system? My boys were reminding me this AM that you had one.
Reactions: Wildman
Just posted on your thread.
Reactions: Wildman and JMT
You won't blow yourself up. About the worse that will happen is you'll feel pretty terrible because you have some nice beads, then you'll do another weld and it will look like shit, which make you feel like shit.
Always remember...
"A grinder and paint makes me the weldor I ain't.”
On that note, Yes Welder is shipping the order in several separate shipments. A little strange, but whatever floats their boat. Received the steel thickness gauge and .030 solid wire today. I think I’ll start with 110V and practice with 1/8” and less steel while I tap into the 220V in the laundry room for the projects if I get proficient enough.
Thanks for the encouragement Mike!
Reactions: D M and PRNDL
Just be sure to never clean metal with brake cleaner. Some have removed the chemicals that react when welding, but I just error on the safe side. No one wants to breath hydrogen chloride or phosgene...
Reactions: starkey480 and JMT
More news. My rear DC arrived at Adams yesterday and I talked to Steve today. They’re going to go over it tomorrow and see what the issue is and let me know when they will get it back to me. I’m hoping it comes back soon so I can get out some and be ready for the snow ❄️.
Reactions: D M and bobthetj03
What should I use to clean the metal before prepping and after to weld? Alcohol? Soap and water?
just do not ever use brake cleaner on metal your about to weld on. some types have a chemical that will ruin your lungs real quick if you flash it and breath it.
Reactions: JMT and Irun
Start with 1/8. Thin is harder than thick.
I pay for Monday, but if I want it there Monday I have to pay almost 3x's as much? Someone is confused.
As the saying goes, sadly, the world is going to hell in a handbasket, and we are destroying ourselves!
"There was a book labelled Book of Origins that indicated the phrase “Hell in a handbasket” referred to the gold rush of 1949 where men were lowered by hand in baskets down mining shafts to set dynamite. If there was a problem or they did not get out quick enough, it was referred to as going to Hell in a handbasket."
The good news is the shaft actually made it to Adams on Monday. 👍🏼
The bad news is the world is going to hell in a handbasket.
Thanks for that interesting history and phrase origin! I love that kind of stuff.
Reactions: DrDmoney and Irun
Yes Welder arrived! No pun intended. I still have to get a Jacket or sleeves, some welding magnets, some clamps, some gloves, and of course the gas.
I believe your machine supports flux core as well, if so - it would save you some cost on gas (and all the related bits), but it's a bit more spattery of a weld. I have a roll on my shelf just in case, but haven't run any through my machine.
Now that you mention it, I believe it does run flex core. Are you suggesting I could get a roll to use for practice? 😊
You certainly could, I believe I got mine at Home Depot - they have a small selection of welding stuff. I got my magnet set from harbor freight, don't forget a few wire brushes, and if you don't have the welder specific pliers you should pick those up.
Reactions: JMT
