Ok, just detach the Savvy TCase linkage, leave it in 2H, manually shift to 4H, back to 2H, and test again. Will do. Thank you.Before you pull the case, disconnect the shifter linkage and manually shift it into the same mode you were in for the test and try it again. If the sound goes away, test drive it.
