So I’ve spent a good week or 2 messing around with it and even took it wheeling!
First thing I did was weld up those leaking V bands and connect my water lines. Now that I have everything aligned I felt comfortable welding them up. I tried copper gaskets and sealant but they just kept leaking.
My HP tuners came in and I was super excited to get some tuning done on this new 2 bar MAP sensor. A couple annoying things on writing a tune is that it will fail mid write if your OBD2 port drops below a certain voltage. It took several days to figure this out, but I have some many small things drawing power when the key is on EVEN with a new battery, I have to put a charger on it while writing.
As far as the tune goes, it’s pretty frustrating. The first thing I need to do is rescale the stock 244 map sensor reference to somewhere around 190. Long story short a out stock 1 bar map sensors reads/sends out a max of 5v reference. A 2 bar Max is 2.5. After about a 30min test drive (that went real well) I got a Low Volt Map Sensor code. The new rescaling sends out a single from anywhere of 0.050-2.5 and the computer reads that as a problem and but the keep into limp mode. I’ve got ahold of a few people to try to help. Typically in most vehicles you can just adjusted the volt reference error points directly and you would just lower the map low end volt setting to 0.01 or something like that to keep the computer happy.
However I guess our JTEC computers use the map sensor as a barometric sensor right before start up and by rescaling those I can potentially solve the problem. I spent about 3 days attempting multiple adjustments but had a wheeling trip planned this prior weekend and for now skipped backed to the 1 bar stock tune. Which honestly does really good for wheeling, but not highway driving. A highway speed I’m in boost for a long time and now it throw a map sensor HIGH code lol.
I still need to work out a radiator tank. Might use the windshield wiper as of now this is my solution lol.
Also I had to remove the fan shroud and it did over heat while wheeling several times. I ordered a 16” electrical fan to hopefully draw some heat from the radiator.
Hopefully soon I’ll be able to figure about this 2 bar map/low voltage problem.
Below are some pics/videos from this weekend. Hopefully the sounds quality doesn’t get effective and you can hear the baby turbo sing!
