Easiest fluid change I remember doing. A hand pump is 100% necessary. My kid did most of the filling.My kid is learning to drive on my ‘05 TJR 6spd. I’ll need to do this soon!
3/27/2026
All of the battery cables have been replaced: ground to block & firewall; positive to fuse block, starter, audio system, and alternator through a new 8 AWG fusible link. I added an SAE connector for easier battery tending. And I plugged in the head unit to see if it makes any noise... and it does! For the first few minutes, though, I couldn't figure out why the sound was clipping so bad. Then I remembered that the blown OE sub is still hooked up. I'll tackle that this weekend.
3/27/2026
With the exception of the battery-to-alternator cable, I made my own. For the record, 25’ of cable is more than enough to run into the cab for amps and do all of the positive-side battery cables…! I put more detail about cable sourcing in this thread.Build your own cables or go with something like Jeep Cables?
The interior is still in pieces… but here’s some of the battery cabling:Pics or it didn’t happen!
The interior is still in peeves… but here’s some of the battery cabling:
When I wire up the winch, I might bite the bullet and have some custom cables made so I’m not overloading the terminals. EC Auto Electric Supply (linked in that other thread) makes that easy.
3/30/2026
152,247 miles (same as 2 weeks ago)
If I had a time machine, I'd go back to May 2024 when I put in the Savvy transfer case cable shift kit and smack myself on the back of the head for not fixing the crappy nutserts. It bit me today.
I installed the B&M Precision Sport Shift tower, p/n 45195. It would have gone in pretty easy, except the lower shift boot didn't want to come off due to the transfer case nutserts spinning. So, I ended up just pulling the boot away and tearing one of the holes (knowing full well how hard to get these things are intact):
From there, I was able to cut away at the nutserts (and a bit of my tub) with a Dremel and get the bolts out. I'll do some patch work and paint to make sure it doesn't rust, and then put new nutserts in.
With all of that out, though... the tower went in easy. If everything had gone smoothly, an hour, tops. But I'll have three into it by the time I'm done with it now.
3/31/2026
Upgraded my WTF account today. Probably one of the more responsible upgrades I've done so far.
