My father is a Marine and lost his left arm in 68.
He used to be able to lay down machine looking welds I could not ever duplicate.
But he is right handed. So he had that going for him.
Welding Vertical welds is my kryptonite
What are you having trouble with when welding vertical?
I always get a gloob welding vertical, I have tried pulling and pushing I have tried starting at the top and the bottom what give
Vertical up MIG needs speed. It also helps to have your gun aimed straight at the middle of the joint with a slight angle 10°-15° pointing upwards. The goal is trying to keep the arc towards the leading edge of the puddle. This will allow the arc to dig into the base metal & give the weld metal a place to go instead of falling out the back & dripping.
So point the Noz up a little in the middle of the weld and use more hand speed and push the bead uphill
This is my oven’s heating element that just blew. I’d say it had energy equivalent to welding based on the look of this!
It was a buzz that got progressively louder for a few seconds and then there was a flash of orange flame and smoke. L
You know some Seabees or Combat Engineers had to come with this Explosion Welding
Welding with danger putty ok its not really Putty
We use that here at work on our engines. Mostly because its an effective way to bond dissimilar metals while maintaining the different properties of each metal.
It was a buzz that got progressively louder for a few seconds and then there was a flash of orange flame and smoke. From what I read up on blown elements that’s how it goes down. But the part in the pic that blew is/was suspended in the air; not touching anything. I don’t actually understand how it doesn’t short out all the time because it has metal brackets on it that connect it to the floor of the oven. I’m guessing the element doesn’t usually conduct well, and that resistance is what gets it so damn hot. But when it fails maybe the power arcs the gap and causes the blaze of glory like this.
Oh well - the new one is in and working! Now I need to do some intentional welding with my new Hobart!
