I'm sure someone has addressed this before but I could use a little help. My 01 TJ had a 4.5" lift on it when I bought it. When driving and you press the clutch to change gears the steering wheel slightly jerks right. I think I've narrowed the problem down. The previous owner put both an adjustable track bar and a drop bracket on the front. I recently found that the front axle is sitting almost an inch to the right. I've seen several people say that the drop bracket can cause bump steer and other adverse effects from poor geometry. Should I adjust then track bar to center the axle or should I go ahead and remove the bracket then adjust the track bar to see if it fixes my problem?
