I first installed mine with 2" lift. I had to cut the threaded rod to shorten the links.I'm curious, can I run an AR on a low-lift TJ like mine, or even a stock TJ? Or are these specific to higher lifts?
Sent from my SM-G950U using Tapatalk
All a sway bar does is connect the body to the axle. The body will want to stay parallel to the axle, minimizing body roll. When you have two sway bars, the body will stay centered between the opposing forces of the articulating axles. This creates stability and predictability that you do not completely get with one sway bar, and certainly not when fully disconnected. When set up well, the Jeep can almost have the feeling of floating over an obstacle.I’ve been looking at these for years. I kinda know what they do, just don’t understand how.
Right, I get what it does, what I mean is as opposed to a standard sway bar.All a sway bar does is connect the body to the axle. The body will want to stay parallel to the axle, minimizing body roll. When you have two sway bars, the body will stay centered between the opposing forces of the articulating axles. This creates stability and predictability that you do not completely get with one sway bar, and certainly not when fully disconnected. When set up well, the Jeep can almost have the feeling of floating over an obstacle.
Mine has been set on the loosest setting for 12-14 years on two different TJs. With good shocks, mine zips through curvy mountain roads and freeway on/offramps without an issue. I never have to mess with its setting and love it as is. I drive it like a Jeep, not like my BMW, and the loosest Antiswaybar setting is perfect for me. Even when towing my pop-up tent trailer. Again, all you need are good shocks... soft or mushy shocks will definitely allow an uncomfortable amount of body roll but good shocks don't.The front AR is softer than stock and stiffer than none (obviously). And it is adjustable. Above where I said a sway bar ties the body to the axle? The factory bar does not allow for much movement, whereas the AR does allow for movent. It is a compromise. I believe the AR should be set to be as stiff as possible without limiting articulation. From there we can get into the discussion of useful articulation and what that is.
I have been daily driving mine for about 4 years. There is increased body roll, but it is very manageable and can be mitigated with stiffer shocks, if desired.
So if you have 2" of lift and had to trim the links...is there more room to trim to fit a vehicle with no lift and everything still connect together the way it should?I first installed mine with 2" lift. I had to cut the threaded rod to shorten the links.
Yes. Plenty have ARs with no lift. I've seen some where the rod ends are nearly touching.So if you have 2" of lift and had to trim the links...is there more room to trim to fit a vehicle with no lift?
Are you saying that the Swayloc front and AR rear is the best setup you’ve run? And that the AR front and Stock rear is a decent setup? Just trying to follow....I appreciate itI have an AR in the back of my LJ and a Swayloc in the front, I really enjoy the swayloc as it's the best of both worlds. I lock it up and it's stiffer than factory. I unlock it and it's a perfect match to my AR. I will never go back to only one sway bar again that's for sure. They provide so much smooth control that I have once had a spotter stop me for fear I'd roll. When u asked what he was talking about he said I had 1 wheel from each axle off the ground. I didn't even feel it getting that way. I've driven a front tire 3ft up a tree and again the jeep felt totally flat.
Best part is, I hit the fire road and flip the switch to lock up the front and drive it like an off road sports car.
Having driven jeeps with an AR on the front on road its a compromise but it's a hell of a lot better than driving with a disconnected front. Off road its no comparison as long as you still have a rear bar. That's one setup I won't ever do again, I started with the swayloc front and no rear at all. Due to an axle swap the stock rear didn't fit. The body of the jeep followed the front axle everywhere, made the jeep really unstable on large obstacles.
There must have been a time
when we could have said no.
Bang on.Are you saying that the Swayloc front and AR rear is the best setup you’ve run? And that the AR front and Stock rear is a decent setup? Just trying to follow....I appreciate it
I suspect it won't, I don't think the torsion will go across its entire length like an AR. Should be interesting to see though.Most of us run a front AR and the rear factory. It's a good combo. The Swayloc is almost certainly better than the AR because of the dual rate, except for the cost.
I'd like to get a rear AR on mine, but it is low on the list. I'll be interested to see how well the factory rear will handle 12" of shock travel. It doesn't limit travel, but can it survive that much? We'll see...
I agree that the front AR and rear factory is a good combination.Most of us run a front AR and the rear factory. It's a good combo. The Swayloc is almost certainly better than the AR because of the dual rate, except for the cost.
That is assuming you prefer the factory on road manners. I have an AR set at the next to softest setting on the front and a stock bar on the rear. I prefer the on road manners the antirock provides because it corners the same with a little more nose dive in corners but you don't feel every bump being transferred from the axle moving. IMO ARs provide better on road manners, more flex while off road plus more convenient that discos.True I forgot about the 3rd and cheapest version that is just an over priced disconnect. To each their own but I vastly prefer the swayloc to be in the stiff rate on road. I've tried it both ways and with bilstine 5120s all around I'm not happy with it in the corners. It really is almost sports car like with it in the high rate setting. I know lots of people run an AR in the front and are happy with it. For the extra couple hundred bucks I feel that having better than factory on road manners is well worth it.
