Probably another 3 weeks I betWe need to get back up there after the snow melts the rest of the way.
Spring Creek. Later in the day we tried Red Elephant, but snow blocked the upper sections of both.What trail is that?
What’s the minimum bump on Currie fronts/rears?ROTM stuff has arrived and the gift certificates have been spent.
I put the money towards a TRE kinetic recovery rope and Currie rear bump stops.
Awaiting word from MilestarDoes... Does this mean you're sponsored now?
We are also in negotiations with Blaine regarding rear frame raisesDoes... Does this mean you're his agent?
Speaking of rear frame raises, I wonder If he ever raised a rear frame just before the shock/tank crossmember. Or why it would be a bad idea?
Interested in your feedback on the install and set up of theses bumps. I had issues with the upper aluminum Currie jounce cup/pad fitting with the spring isolator. I also had to add 1.5" to bottom bump (I borrowed the bottom spacer from the front Currie stop kit for now).ROTM stuff has arrived and the gift certificates have been spent.
Flange nut sounds like a good solution. You'll also likely find that the isolator is too big to fit nicely in the Currie Cup and pushes it down too far making the bolts that came with the kit too short. I had to get longer bolts. Tried trimming the isolator but didn't help enough. (Although I didnt install it this way, It would fit when flipping the cup "upside down" from what the instructions show.)Install is trickier than it ought to be on mine. I need to rebuild the lower pad after drilling it out for the old air bags. I'm thinking of welding in an upside down flange nut to give me something to bolt on to.
I trimmed the inside of the isolater to fit over the aluminum spacer easier. I then pre-installed the aluminum spacer into the spring and then fit the isolater over the aluminum spacer. This makes install and removal so much easier and quicker. It all becomes one piece, less to fight with. This allows you to feed the upper urethane bump stop in and bolt it to the frame without a balancing act.Flange nut sounds like a good solution. You'll also likely find that the isolator is too big to fit nicely in the Currie Cup and pushes it down too far making the bolts that came with the kit too short. I had to get longer bolts. Tried trimming the isolator but didn't help enough. (Although I didnt install it this way, It would fit when flipping the cup "upside down" from what the instructions show.)
Edit: below is how it fits the "right" way according to thr instructions.
Do you have a pic? Is there still enough meat on the isolator for the coil to rest against? I thought about that but didn't want to trim too much.I trimmed the inside of the isolater to fit over the aluminum spacer easier. I then pre-installed the aluminum spacer into the spring and then fit the isolater over the aluminum spacer. This makes install and removal so much easier and quicker. It all becomes one piece, less to fight with. This allows you to feed the upper urethane bump stop in and bolt it to the frame without a balancing act.
