Ok guys, Im going to leave everything as is and see if I can just change out the coils to 3 inch. Not sure if anyone sells just the coils but will begin looking. This should make me feel better about 33s and the vibration will hopefully go away.
Did you measure the current coils?Ok guys, Im going to leave everything as is and see if I can just change out the coils to 3 inch. Not sure if anyone sells just the coils but will begin looking. This should make me feel better about 33s and the vibration will hopefully go away.
You won't be sorry, beautiful drive the whole way and great little towns to explore along the route. Highway 49 will connect you to more backroads than you have time for, just be sure to bring a good gps.Hwy 49 sounds like a fun trip. I was just looking at it on the map yesterday and talking to my wife about it.
Thanks all for the comments. I’m parking it for now. Don’t want things to start breaking and flying off. I’m traveling the next week but going to see if I can get ahold of the sales guy at 4WheelParts. I specifically asked if I’d need a SYE or double cardan driveshaft or anything else when we were building out the options and he told me “no.”
I do have a transfer case drop. I agree that springs will not settle much. May just change the springs to 3 inch or so and call it a day. Trying to find out who sells tbe springs only. Did not have a chance to measure yesterday but will measure today.
.... Maybe 6 months later I removed the drop and added an SYE/CV and it helped more, but still didn’t solve the problem. Maybe 6 months later I added the adjustable upper rear control arms & tweaked the pinion angle & boom, problem solved. Point being I drove it the whole time & nothing exploded.
It is worth noting for clarity that the SYE/Double cardan rear drive shaft also requires that the pinion be raised using adjustable control arms. It's the nature of the beast. Not raising the pinion is almost a guarantee that the vibes won't go away.
That thing looks just about perfect, @lowranger. Only way I'd like it better was if the title was in my name!3.5" Rubicon Express lift with 33" tires.View attachment 45035
That's some funny stuff right there!! :risas3:That thing looks just about perfect, @lowranger. Only way I'd like it better was if the title was in my name!![]()
Thank you Squatch! I like it.Seriously, though, it just looks right. :thumbsup:
So 4 inches a little more than expected. May seriously consider getting shorter springs
What exactly are you trying to accomplish? There are likely more than one solution to the problem. But before just throwing more money at it with a shorter spring, know what you are trying to achieve.Wonder if Zone would sell their 3 inch springs so I could replace them with the rubicon express
X2What exactly are you trying to accomplish? There are likely more than one solution to the problem. But before just throwing more money at it with a shorter spring, know what you are trying to achieve.
This would be a good solution.That might be typical of Rubicon Express on a light weight build.
2.5-3" with a small body lift and a mml would be a good way to go. You get the needed clearance for 33s while keeping the rear drive line flatter than if that was all done with a spring lift. This is the reason so many recommend the Zone 4.25" combo lift.
