I am getting to the point that my TJ might need an engine sooner than I'd like. Its always had a little tap when cold but now its getting to be a pretty good piston slap and I'm getting misfire on cyl 3 codes on occasion that come and go. I've not done a leakdown or compression test yet, but that did get me thinking...
I've done quite a few swaps in the past so its not my first rodeo.
I am thinking that while I do quite like the 4.0 in there already, another 50-100 (or more) hp would be nice. A rebuild is an option, go with a stroker kit and stick a mild cam in then get it tuned. That has a large enough price tag that it might be worth looking at a swap anyway as I'd be replacing the transmission while I'm at it. But, it is the easiest and the most sure fire.
One thing that hangs me up is transmission length. I hate that I love short wheelbases. I fought this in the Samurai when I did the ALH TDI swap and looks like I might fight it in the Jeep too.
An LS is an awesome engine option. Maybe with an NV3500 behind it? Nv4500 is what I want but its also YUGE and I'm not keen on doing what it takes to force it to fit. I can do it, but I don't wanna.
A hemi would be sweeeet, but I've never seen one swapped with a manual behind it, always an auto. Any manual trans options that fit in a TJ?
A magnum is also a good option, also possibly with the NV3500?
A wildcard engine would be an OM648 with something behind it. I do quite like a diesel and those are some fantastic motors. No idea on what trans, but it'd be fun. This would be the most work but the mileage would be an excuse to do it. It would never cover the cost in fuel savings, so literally just an excuse.
IDK, kinda daydreaming at the moment on what I could toss in there and enjoy. I'm pretty well resolved to keep this TJ for a long time to come as its super straight, totally rust free, does everything I want, and has so few electronics even @Zorba likes them. So if I do it, it needs to be reliable, it needs to be reasonably easy to work on, run on regular gas or diesel, and be something that I can get in and just drive. Right now, the stroker 6 banger and an AX15 really do check the boxes the best, but life is short and sometimes you just need a V8 or diesel Jeep.
