Definitely still bowed yes. It looks like the drivers side wheel is further out from the body than the passenger side from my views
Reading back through, this combined with
@AndyG and
@Bigmac suggestions make sense. If it was mine, I'd reset and rethink like this based on their input, but first measure the towers right now, what is the distance I think stock is 12" in front, what is yours currently.
1. The axle looks shifted way to driver's side. (That's the Track bar being stock, too short for a lift) Makes sense.
2. Disconnect the track bar.
3. Get on the front bumper and literally bounce up and down to settle the axle. (Maybe even loosen CAs again, but try without it first).
4. Looks and see where the axle sits, does it look more even.
5. Has the spring changed on drivers side at all?
6. Lastly, if that doesn't do anything, measure that spring free from the Jeep, and make 100% sure from RC those are the correct springs, and not 4" or something. They are the same, but both can be too long, stranger mistakes have happened.
If it corrects without track bar connected, you need a new one, adjustable in my opinion.
