some PTO shaftWhat passes through the window? I found a few similar examples, but no clear installed images.
Isn't that because the 2.4 didnt have enough power to turn a manual fan?
They had a large hydraulic pump with a driveshaft that turned it which connected to the front of the engine and passed through that hole in the radiator.What passes through the window? I found a few similar examples, but no clear installed images.
I have to ask. were these *new* Mopar radiators? If so, you seem to have incredibly bad luck compared to the vast majority of TJ owners. If they were used radiators, then what do you expect? Nothing lasts forever.
Can't really conclude much from the failure of an aftermarket or used radiator.
Look on the bright side. Once the OE Mopar part supply dries up, then we'll all be at the mercy of the Chinese (i.e. Mishimoto garbage) and any other local auto part store brand we can find. At that point we'll be forced to run any radiator we can find, including some of the sketchy aluminum ones.
I'm pretty happy having changed mine in September of Last year. The way my TJ is going, the rest of it will rot away and I'll have a nice new'ish Mopar radiator to put in my next one!Glad I found an OEM back in 2016 then. Should be around 2035 by the time it needs replaced. I'll cross that bridge when its time.
Technically the cap doesn't leak any more than the core does. The most common leak in that area is the o-ring that is used for the seal. It shrinks when cool and expands back up when it gets up to operating temp. The leak has nothing to do with the fact that the cap is plastic, the gasket losing resiliency is the issue. I'm not going to fault Mopar too much over that since some pretty smart folks at NASA managed to blow up 7 astronauts (actually 6 and 1 civilian, but whose counting?) over the same issue.Let me show some ignorance here... Back in the day, radiator shops could fix lots radiator problems. Isn't there any way that a Mopar OEM radiator could be retrofited with a steel or aluminum cap to fix the problem of the plastic cap leaking? The only problem that I have ever heard about with the OEM radiator is that plastic cap. It seems to me there should be a way to fix that cap issue and save the rest of the radiator. I'm sure its been tried. I'm not that smart to be the first one to think of it. But I'm curious as to why the OEM radiators can't be refurbished.
A metal cap would have the same problem. I have watched some of the OEM radiators weep in that area for a couple of years and none have failed catastrophically due to it. They generally stop when the engine gets up to temp.
The reason it is hard to refurbish is due to the crimped connection. The metal fails or is problematic when you undo the crimp and re-crimp the new tank on with a new gasket. Some folks have reported success with taking some vise grips and crimping the tabs a bit more to slow down or stop the weeping.
YesAre you saying there is an o-ring between the metal core and the plastic top of the radiator where it's crimped together somewhere/somehow? I've never pulled one apart.
For whatever reason, no one at Northern has ever installed one in a TJ with AC. The grill has to come off with the condenser in place because there is no room to unthread the fan clutch and get it out of the way and not enough room between the radiator core and end of the fan clutch to safely drop the radiator in.Bring out yer dead... Ding. I'm digging this up as blaine posted in it and I have a question for him that could be useful for others in the future.
@mrblaine I know you have some experience with the Northern radiator that I have in my Jeep and I have question about the condenser in relation to it. I bought the radiator having no AC but remember you mentioning something about an issue with condenser fit along with the Northern. Do you remember what that was? I just ordered a Jeep Air kit for my 2001 and am trying to get ahead of the curve with what might be to come.
I have not installed one with the earlier fan clutches so it may not be an issue with that style. I know I'll never install another one. It is ridiculous to have to remove the grill to install a radiator.
Also, I believe that the radiator has to be spaced towards the engine off the grill mounting flanges to keep it off of the condenser. If you have the threaded fan clutch, I suspect you will wind up disliking the Northern as much as we do.
Mine was leaking when I pulled it out to install my AC. If you have an AC condenser good luck fitting the northern radiator without going to electric fans. Go OEM. I bought a cheap one from a parts store to get me by for a while until I have time to order a Mopar unit.As someone who is 2 bolts away from removing the grill for other reasons, do you think there'd be any benefit to going with the Northern radiator for me? For everyone playing at home, I have a supercharger and roller rockers adding 50-70hp and am highly considering stroking up to 375-400hp in the future. I'd rather swap in a good radiator now that will work well later than buy an OEM radiator now and pay again later to swap to something else in the future.
