When I swapped the axles a couple months ago I replaced all 4 rotors and pads. Although after this last wheeling trip I have some dirt that is causing a squeal somewhere.Lots of elbow grease! Do you plan to replace your brake rotors?
You think my shocks are too long? I would think they are too short since they are limiting. School me on this.Yikes...4" of bumpstop seems excessive. You only have 3" springs, right? I'd say your shocks are too long...So the compressed distance is too long. It also looks like your bumpstops are going to hit your coils as soon as that suspension starts to cycle.
Since its Sunday email is probably going to be my best bet reaching out to him. I would think the shocks are too short, but you guys are telling me they are too long. Trying to comprehend the reason why they would be too long vs being too short and requiring the additional bumpstopping.Those shocks can't be right Jimbo. Looks like they sent you shocks for 4" coils. Definitely get a call in to Gerald. Leaves you very little suspension travel. Gonna ride like shit brah.
Thank you! I have emailed Gerald, just pulled up my original invoice to ensure I purchased the right shocks:It's all about collapsed length of the shock. At full compression, the shock is too long and is bottoming out way too soon, so you need a shock with a shorter collapsed length, so you don't need so much bump stop. Yes, you will sacrifice some extended length. The idea is a happy medium. Not sure why Fox doesn't advertise their shock sizes.
@bobthetj03 hit it on the head. When those shocks are compressed, they are not allowing enough up travel. Did you put bar pin eliminators or anything in? Those add about an inch to your compressed length too.You think my shocks are too long? I would think they are too short since they are limiting. School me on this.
No I don’t have bar pin elimators, shocks are stock.@bobthetj03 hit it on the head. When those shocks are compressed, they are not allowing enough up travel. Did you put bar pin eliminators or anything in? Those add about an inch to your compressed length too.
Yeah we will see, no idea why they aren’t listed on the website.Your invoice doesn't list the part #'s of the shocks, so not even sure how you'd know if you have the correct shocks or not. Hopefully Gerald will shed some light.
This is an example. Rancho's website lists the part# of the shock, along with the shock's collapsed/extended lengths.
http://www.gorancho.com/products/sh...er/rancho-rs5000x-shock-absorber-rs55241.html
Seems like a PSA is in order to double check your bump-stops forum wide.Guess I need to practice what I preach. While waiting for the engine to cool to replace my valve cover gasket yesterday, took some measurements while the jeep was on level floor. I hadn't checked things since putting the RS5000X's on. I'm good up front, but the rear needs another inch of bump stop extension. I think I may have lost of bit of shock travel when I relocated the bottom mounts in prep for the SYE.
Luckily for me, I had already drilled/tapped a hole in the lower spring perch, so I should be able to snake a puck in there without pulling the springs. Sucks you have to pull a shock.
How much up travel do you have, and what is the total travel of the shock? You generally want about 50/50 or 60/40 down bias to prevent tire contact.
Same, although curious how you knew you needed another inch of bumpstop without pulling the springs.
None of the factory orfab was taped on the side and all contents were where they were supposed to be so idk. Stoked though, looking into different paint options now.Me thinks that was a return at some point in it's life judging by the re-taping of the box...that is why you found it after it was discontinued. I bet they would have not resold it if it was still in production. Looks like it will work out great though...enjoy.
