I have the opportunity to purchase this LJ and I am second guessing how clean the frame looks. It's definitely been patched in 1 spot, but I don't think the rest looks bad for having 176k miles on it. What does everyone else think?
Where's the patch? If it's the first pic above the LCA then that's normal from Jeep. Other than that it looks pretty good and has obviously been painted. I'd check it out closely to make sure they aren't hiding something.
I assumed the the top section in the first pic was a patch. Problem is, it's 400 miles away from me.
A lot of the paint makes me skeptical. Mine is very smooth. That paint looks rough. I see the patch too, which also concerns me. 400 miles is a long way to go to look at something you’re skeptical about.
Second pic from the top...
- Lower bushing on the center body mount is rotted out; wasn't replaced and was just sprayed over.
- Check out the tub above that body mount and in front of it. Looks like it's bowed...or could be a bad camera angle.
- In the same area, the paint on that bowed looking part of the tub is either peeling badly or covering something that wasn't cleaned/repaired well if at all.
All of these would make me skeptical.
Lots of fresh paint on that frame and underbody. looks like the skid plate is pretty crusty under that paint layer, Body mount tabs on the frame look crusty as well. hard to tell from the photos but if thats all your given I would suspect theres unpainted ugliness selectively not photographed. looks like you would be alot better off looking at it in person.
looking even more, door hinges are rusty, something weird appears to be going on with the body paint where the warn logo shows in the 3rd photo. im thinking the rail was added to cover up rot. last photo the bottom door hinge pin nut appears to have been seized and broke free. looks like hella spray painted rust on the body component directly above the lower control arm bolt in the first photo.
Im thinking this one is a good attempt at coverup for high dollar.
You really need to see the inside of the frame, I know that not easy from 400 miles away, Maybe someone can get a borescope and look for you. If it were me, I would not trust it without inspection.
Looks like it's 400 miles from you in the wrong direction. Head south.
