I recently installed a set of Wheel Vintiques 14 series wheels on my LJ and am getting a some vibrations from them. The new wheels and tires were road forced balanced so I don't believe the its balancing thats causing this. I just dropped the jeep off at edge 4x4 in Denver this morning to help solve a driveline vibration turned which out to be U joints and balancing (those guys are great by the way). They called out my wheel issue as being the lug centric wheels are not actually centered on the hub. I have read a bunch of threads about proper way to tighten the wheels which I will be doing tonight to see if that solves my issue. If not there doesn't appear to be any hub centric rings that fit my wheel bore (3.125") for the hub bore (71.5mm), and with the wheels being steel with a thin flange I don't know if I could use them anyway.
I am thinking about making a tool that is essentially a ring thats the same wheel bore OD (3.125") and Hub Bore ID (71.5mm) and just using that as a spacer to help me line up the wheels when mounting. You would remove the spacer when done installing the wheels. Am I over thinking this?
The Wheel vintiques accept a 60 conical lug nut and I believe that is what our factory lug nuts are which I am using...
