I'm going to build on of the compact j-series trailers. I really like them.
I also want to build one eventually. I like them a lot. I sure they sold built trailers!
Is it running warmer than usual?
A pressure test “might” help diagnose it faster and more efficiently.Not yet, but was loud enough my wife actually noticed it. We stopped at the cabin and she was like.
“Ummm is that noise your Jeep?”
Next time I take a longer drive to warm it up I’ll see if the cap fixed it.
It uses pressure to test for leaks. Install the tester on the neck of the radiator in place of the cap, in this case, or the coolant reservoir(i have yet to try that, but it would test the cap), and pump until you reach the pressure marked on the radiator cap. Think bicycle pump. Check around the engine, hoses, hose clamps, thermostat housing and it’s mating surfaces, radiator, radiator plastic tanks, for leaks, little bubbles, or air escaping indicating a leak. You can check inside on the passenger floor area and under/behind the dash area for heater core leaks.How is that done?
Easiest way is with a new radiator cap.How is that done?
Try a new cap first. Or, do it like everyone else does. Hey, my valve stem is leaking, time for a new set of tires.Mine has been doing this lately too. Sounds like someone is taking bong rips from my radiator. Only after long-ish rides. Might be time for a new radiator.
How do you feel about child labor? Charlie also loves washing cars.... I think between the two of them nobody would be able to resist a car washSome days are just better than others.
View attachment 160889View attachment 160888View attachment 160890View attachment 160891View attachment 160894
She was a washing machine, helped me do the whole thing.
You beat me to it!Just don't forget to wash the other doors![]()
