Currently wrestling with a silly little TJ. (97)
Had O2 sensor codes and rough idle with loss of power before engine reached “closed loop” temps. Replaced O2 sensors (with the ones recommended by the updated O2 sensor thread) and it ran fine. Drove about 1800 miles then bang O2 codes again.
Codes are for “Heater Element Performance Or Rationality Malfunction” and “Input Voltage Maintained Above Normal Operating Range” on both sensors.
I tested the heater on both and upstream measured 5ohm downstream measured 4.8ohm. Don’t have whisker leads to test the voltage on the sensors while running.
Is there a chance that my PCM is just wigging out? Current issue is intermittent rough idle and loss of power while engine is below “operating temp” but it generally seems to right itself shortly after warming up.
