Cool ! Yea with me lifting the Jeep and all I won’t be trying to corner like a Le Mans driver![]()
Trust me, unless you’re a sensitive Sally, you’ll barely notice it.
Ok cool ! I am certainly starting to understand the whole just empty every pocket ! Ha! I thought my Nova cost me a lot of money , it’s not near as money hungry as my LJ .Trust me, unless you’re a sensitive Sally, you’ll barely notice it.![]()
Ok cool !! One less thing ! Ha! Yes I am gonna go with those ranchero shocks everyone seems to like !You probably won't need the rear drive shaft with the Unlimited. Especially with doing the body lift and MML.
I will say the OME shocks were great on smooth highways. Nice and tight/stable. But areas like expansion joints where highway and bridges meet, patched asphalt, man hole covers, etc, would jar you pretty hard.
Yessir!Ok cool ! I am certainly starting to understand the whole just empty every pocket ! Ha! I thought my Nova cost me a lot of money , it’s not near as money hungry as my LJ .
so
1.25 savvy body lift
Antirock
OME springs
Rancho shocks
Currie adjustable front and rear track bars
Motor lift
so this should allow me to run 33 safely. XS? Thanks for all your help![]()
Looks like a good list. If you do all the above and experience driveline vibes then you can drop the Tcase until you can do a sye and Tom woodsOk cool ! I am certainly starting to understand the whole just empty every pocket ! Ha! I thought my Nova cost me a lot of money , it’s not near as money hungry as my LJ .
so
Antirock
OME springs
Rancho shocks
Motor lift
Oh my gosh !! Man I can’t play in your league ! LolYessir!
And yes, dropping 10k on one of these things is very, very easy. I spent 45k on my last one, not including the cost of the vehicle![]()
Cool ! Sounds good !Looks like a good list. If you do all the above and experience driveline vibes then you can drop the Tcase until you can do a sye and Tom woods![]()
So on the front and rear adjustable track bars , is there a particular one you recommend by Currie ? I have just rebuilt the front and rear suspension but I am all stock . Thanks, KegYessir!
Also they make Antirock for rear too ? Do you have this as well ? I was thinking we were only talking front but you may have meant front and rear ? Thanks KEG and sorry for all the questions!So on the front and rear adjustable track bars , is there a particular one you recommend by Currie ? I have just rebuilt the front and rear suspension but I am all stock . Thanks, Keg
I've been running Antirocks for 16-17 years adjusted to their least stiff setting. I regularly tow my pop-up tent trailer through the mountains on tight twisty roads, I keep up with traffic, and I have zero issues... it handles fine. This who claim it doesn't are victims of of the power of suggestion and the rumor mill. Or they running soft mushy or worn out shocks.I was reading about the Antirock , how are it’s manners on the street ? I have to be careful going to crazy on mods because of pulling the camper .
Thanks !! I appreciate your input on this since you pull trailers as wellI've been running Antirocks for 16-17 years adjusted to their least stiff setting. I regularly tow my pop-up tent trailer through the mountains on tight twisty roads, keep up with traffic and have zero issues... it handles fine. This who claim it doesn't are victims of of the power of suggestion and the rumor mill.
I run the Antirock up front and the factory rear antiswaybar with extended links.Thanks !! I appreciate your input on this since you pull trailers as well
Do they make a front and rear or just front ? Have you run both of they do ? Thanks![]()
Sweet ! Good to know , thanksI run the Antirock up front and the factory rear antiswaybar with extended links.
It wouldn't hurt but not absolutely necessaryWould extended links be a good idea with me only having 33’s on 16 inch rims and a 1.25 body lift and 2inch spring lift ? Thanks![]()
What kind should I be looking at ? Doing a Currie track bar in rear as suggests on previous posts ,It wouldn't hurt but not absolutely necessary
