Technical question for you jeepers, Doesn't GL-5 gear oil already have the limited slip additive in it? Do you still need to add the additive for LSD rear ends?
In preparation for my SYE, I want to replace the front input yoke.
Is there any reason why this input yoke wouldn't be the same for my 03 TJ, NP231 TC? It says up to 99, but aren't the 231's all the same up to 06?
http://www.omix-ada.com/np231-front-output-yoke-97-99-jeep-wrangler-tj.html
AC was blowing warm in the Jeep, so off to the AC shop it went. $93 later and AC blows cold again. Got dye in the system now, so hopefully we can find the pesky leak.
That dye stuff works great. I had the same issue for mine, it simply turned out to be a small o-ring seal where one of the main lines connects to the compressor.
Looks good! What brand are those rear shock relocation brackets?
I'm going to order some of those then. I've needed a set for quite a while.
You won't be disappointed. Fit and finish was top notch. Now the question remains, should I cut off the old shock mounts, or just leave them there?
