Initial ride height of 4.5" RE front springs including ACOS
19"
Bilstein shocks
24.25" extended
14.25" full compression
10" shock?
7" shaft showing at ride height.
Doesn't that tell me I had 7" up, 3" down travel?/ Hardly 50/50
Removed ACOS and put the springs, shocks and tire/wheels back on. Trackbar disconnected at the axle, Anti-Rock disco also.
New ride height 17".
Driver 4.75" shaft exposed
Passenger 5" shaft exposed
Very close to 50/50 on 10" shock, correct?
My conclusion is that the Bilstein shocks are the correct length for 4.5" lift (RE springs) without the ACOS in place at 2" added. And I should be able to order shocks of equal dimensions to the Bilstein and end up near 50/50 up/down.
I'll cycle this one more time to confirm my measurements and after installing the new RJ trackbar in a couple weeks, hoping it clears the diff cover.
I might move on to the rear while the front is semi-assembled. I expect to find much the same results when the relocation bracket is removed and the rear springs are back in their stock bucket.
