Band saw? And are those different material from the big bumps in my picture (not the hockey pucks)? I think that's probably a RE bump.I would go further, but I also used hard plastic body lift pucks that I cut to length.![]()
Yours looked like plastic. The Zone body lift pucks are also plastic. I used a table saw. But a band saw is safer.Band saw? And are those different material from the big bumps in my picture (not the hockey pucks)? I think that's probably a RE bump.
A pair of each or 1 makes 2?Yours looked like plastic. The Zone body lift pucks are also plastic. I used a table saw. But a band saw is safer.
These work well for the front and rear lowers.
https://liftkits4less.com/zone-offr...BxKse7upc_RjUxXxXi64brkWaMt2PN1xoCiL8QAvD_BwE
And these for the rear uppers.
https://liftkits4less.com/zone-offr...xNo8owSV6aiwFidBdBEn-O7BrCfbpKAhoC26wQAvD_BwE
Dunno how 'dead-eye' I'll be with round stock in a band saw. Creative clamping I guess. I have a metal blade in my chop saw!
Front and rear cups are identical, as are the yellow jounces.Oh crap! Is there a cup in the rear? Only ordered 2 for those missing in front. Maybe the rear cups are still there with the relo bracket.
Hijack my build thread? We can't let that happen!Time for a look/see.
Another topic but didn't want to hijack your build thread. I have AntiRock. I noticed your concern about that with your "affinity for soft shocks", then you went to SwayLoc. Of course, you got me re-thinking on the BM shocks with AR.
Dang, I'm all over the place.
Are the formerly 'everybody's favorite' Rancho 5000x a 'tweener' soft/jittery?Hijack my build thread? We can't let that happen!
I don't really like soft shocks. I just don't like jittery shocks more.
And the AR is a very good sway bar. But for a rig that also sees a lot of street use in addition to offroad, the SL is better.
Based on my experiences, the 5000x is soft and mushy. The 5100 transfers the annoying small road events more than they should, but beyond that they are a decent shock.Are the formerly 'everybody's favorite' Rancho 5000x a 'tweener' soft/jittery?
I'll be just fine once these 5100 are gone... unless it's the springs that make it ride so rough.![]()
All shocks suck until you get tuned outboarded shocks. That being said ranchos do okay for me. The rear shocks suck more than the front ones do but it’s tolerable. Would definitely like to outboard the rear soon.Are the formerly 'everybody's favorite' Rancho 5000x a 'tweener' soft/jittery?
I'll live with what I choose. Outboarding is way down on my list unless I learn to weld and a whole lot more. Would like a ride in a heep with it done, tho'.All shocks suck until you get tuned outboarded shocks. That being said ranchos do ok lay for me. The rear shocks suck more than the front ones do but it’s tolerable. Would definitely like to outboard the rear soon.
That's good news. I'm hoping getting rid of the fat G2 cover will cure the interference but if not, I'll call RJ. At least there's a light at the end of my current tunnel.As for the trackbar hitting the diff, the rockjock trackbar has more bend than the rubicon express one. We just replaced a rubicon express trackbar with a rockjock on my dads rig and it helped clear the diff
I think I'll give the KYB Monomax a shot when it's time. I found them with p/n you posted on another thread. Fortunately, I took a pic of the screen so don't have to research the thread. 565096/565097. Looks like they match closely the length I'll need (still have to cycle the rear). They're either back-ordered 'til January or only front available the places I looked, so I'll keep trying until I'm ready to roll.Based on my experiences, the 5000x is soft and mushy. The 5100 transfers the annoying small road events more than they should, but beyond that they are a decent shock.
The two (three) that I would like to drive are the Skyjacker BlackMax, the KYB Monomax and the KYB silver bodies.
The bottom line is that people need to experiment more. As well as understand the differences better.
I think I'm finally seeing what you're asking. Are you referring to the tire and fender picture? Thinking a shorter shock and less bump would allow more uptravel and get the tire closer to the fender?If you had a shorter shock (and less bump stop), how much farther could you go? In other words, what would hit next?
Tires to fender?
Just pointing out that you might get more overall travel with a shorter shock since most can't use all the length available anyway.I think I'm finally seeing what you're asking. Are you referring to the tire and fender picture? Thinking a shorter shock and less bump would allow more uptravel and get the tire closer to the fender?
