Sounds like a short somewhere... Similar to Josh's flex issue he had...
Maybe, I’ve pulled the whole loom to check that about a month and a half ago - so it would be surprising.
It could be worse...it could have the vibes.A fresh tank of gas and the Jeep was acting better. We’ll see over the course of the week, but why is this POS so sensitive?
If there is any shorts, I can’t trip them playing with the wiring harness.
Have you check the electrical connections at the fuel pump?
considering you've gone through most of the sensors and ignition system from what I remember
When I was chasing my problem years ago, I thought it was the fuel pump when I was able to get the Jeep into a position where I noticed the pump shutting off. I replaced it and didn't fix anything. Eventually I noticed that when the fuel pump shut down, the ASD relay was activating which is what killed power to the fuel pump. That is when I started looking at sensors.
Regarding the bad gas, there was a moment early on where I also thought this was a fuel problem, specifically vapor lock. That is how I ended up with the full Injector and fuel rail insulating kit.
How’d you trace through wires to find the short? I’ve been through them so many times now I’m probably desensitized to something.
I did notice my fuel gauge seemed inconsistent the last couple of days - which could be at least the sender. It was at 1/4 randomly then back close to just under a half on a similar grade.
Pure luck. There was also a moment where thought the problem was with cracked wire insulation in a really difficult area above the transmission. I could poke a fat wire bundle with a stick and kill the fuel pump. But I poked it enough that I stopped happening. After tipping the transmission down and inspecting the area I couldn't find any bad wires. I started pulling sensors and eventually had everything out back to the fuel pump. I put it all back together and the problem hasn't come back in the last 4-5 years. My best guess is that one of the o2 sensors I had replaced a free months earlier wasn't seated properly and would open up if the Jeep was twisted up just right.
I guess my point is that if this isn't the PCM, I strongly suspect this is still a sensor connection. And that it is really easy to lost on multiple wild goose chases trying to make sense of things that don't make any sense. I got really lucky in that I found and could recreate the situation that triggered the ASD.
Look at every wire at every plug connection.
