Can anyone ID this suspension brand? It looks pretty complicated…obviously BDS steering…but is it a BDS long arm lift?
Thanks! I’m just trying to determine if it’s gonna be a shit show to drive or replace the crap pieces!I see the following...
Fox 2.0 remote reservoir shocks in the factory mounts.
Some brand of aftermarket rear sway bar that I can't read the name of.
An adjustable rear track bar.
1.5-2" rear coil spring spacers
A standard bolt on long arm.
Currie/RockJock CorrectLync steering
A dropped pitman arm
A dropped front track bar bracket
An adjustable front track bar
Dual steering dampers with a stupid axle bracket
Front sway bar disconnects
An aluminum radiator
There isn't anything complicated. There is a lot that is more show than function. The best pieces you have are the steering and potentially the rear sway bar.
Neither. Nothing is going to explode on you (except maybe the radiator). Use it and figure out what you like and don't like over time.Thanks! I’m just trying to determine if it’s gonna be a shit show to drive or replace the crap pieces!
That is 100% the rear sway…It definitely says Teraflex on the arms…good find!Rear sway bar looks like an older (discontinued) Teraflex sway bar system.
I don't know much about it, but had a friend that had one years ago.
Random Google pic
