Now that the case is finally up after having to reclock the studs. Onwards to the y-pipe we go.
I think I might look into an xj shifter setup as I think that might have an extra gear that would work with the 6L80e.
Aren't they the same as a 03 or newer TJ shifter?
You should have 6 detents? The 6L80e is a 6 speed? Or is it more like the 8HP trans where it's all electronic?
Kilduff makes a nice looking shifter for the 6L80
https://www.kilduffmachine.com/store/p176/Road_Ripper_6L80_/6L90/_8L80_swap_shifter_#1296.html
That is nice , I had already bought the adapter from novak to make a factory shifter work. Im going to check out this setup.
