Yes. It uses the existing nutserts and bolts on the bottom of the frame. The cross member has holes for the nuts and bolts that go on the outboard sides of the shackle mounts. I drilled the other 4 inboard ones and added nuts/bolts and the largest washers I could fit to further spread any loads.does it tie into the frame?
