Where did I say no difference?Jerry, you said you noticed no difference. No difference in that they were smooth either way or no difference in that there is slight vibration either way?
?Not always and not necessarily. I stopped paying extra for Road Force balancing as it was not producing better results for me after several uses of it.
It makes sense to balance tires when they're still warm from driving but wow I've just never seen a tire shop start on a balance job unless the vehicle has been sitting at least an hour or more. My last two jobs I had to drop it off the night before.
Wouldn’t a ‘flat spot’ on a tire get rolled out after just a few revolutions? For example driving across the parking lot? I’m not a tire guy, but just wondering
When I drove a milk truck about 3 decades ago we ran bias ply tires, they would get a serious flat spot that would probably let go after several miles
Except for new cars, cars with new tires, cars that never get their tires rebalanced.I sincerely doubt that "flat spotting" while waiting to have your tires balanced is the contributing factor to your imbalance problem. If that was the case there wouldn't be a car on the road that had a smooth running tire.
Still not going to agree with that. I worked in the tire business for a combined total of about 10 years and very seldom did I ever have a customer come back in with complaints of tire vibrations after switching from winter to summer and vice versa or for any other tire related reason. So that negates the only with new tire concept. Some drivers are more sensitive to the ride quality of their vehicle, some are oblivious, some cars (GM trucks) are more prone to transferring vibrations through to the driver better than others.Except for new cars, cars with new tires, cars that never get their tires rebalanced.
Of the ones left remaining (cars with tires that have been rebalanced), some of the drivers are probably insensitive to vibrations. Of those that are sensitive, some of them probably don't do enough freeway driving to make a big deal out of it. The small percentage of people left are the people that go online and complain about X tire store or brand X tires not being able to balance.![]()
At the deepest part of the flat spot, you measured .059", and it tapers back out to original circumference from there. That wont change the centrifugal force substantially enough for any balancer to sense a weight imbalance.I would point out that switching from winter tires to summer tires would not have flat spots because they are coming off the shelf and onto the car.
Either way, I think you are right that it probably doesn't matter.
Flat spot affected about 25% of the circumference of the tire. Tire weighs 21.3lb. Even if 25% of the entire weight was moved .030" that would be 2.34oz-inch which is equivalent to just over .25oz where the weights would be placed. Not much.
Maybe if the blind or rounding function of the balancer happened to stack up with the flat spot...could be up to .5oz off. There is ~ 70% chance that at least one of the four tires have the spots stack up in the same quadrant and all it would take is one tire.
I would sure like to know more about the BB ’trick’ Anyone else tried this?…and added 2 oz’s of copper coated BB’s to each tire and they were still perfect when I sold the Jeep a year later.
It’s nothing new, people have been doing it for many years now. I’m just the first person I know that left the traditional lead weights on as well and have had great success.I would sure like to know more about the BB ’trick’ Anyone else tried this?
The trucking industry has been using balance beads for a long time vs trying to add metal weights to the rims. it helps with radial balance but not so much with dynamic.I would sure like to know more about the BB ’trick’ Anyone else tried this?
New, old, doesn't really make any difference.So 2 0z per tire and it will help with the balancing? Would a person add them to new tires as well?
They do work but they are limited in what they can do. I linked an article a couple posts back that hits on the drawbacks and benefits.Found this: https://www.innovativebalancing.com/
Mudders, Rock Crawlers and Oversize Tire Owners need Dyna Beads®!
We have a special chart for the owners of large, aggressive-tread tires similar to those produced by Michelin, Continental, Interco, BFGoodrich, Mickey Thompson and Toyo, among others.
Your unique and specialized-function tires and Dyna Beads make an ideal team!
- Special Off Road beads for superior performance in large, aggressive tires.
- No need to mess around with "balance patches", which are only accurate at the time of installation and a pain to install.
- Wheel weights, regardless of type, are inefficient for balancing these tires, due to the distance from the outside of the tire to the rim, not to mention how it looks to have 3 lbs of wheel weights hanging on your rim.
- These aggressive, oversize tires change their balance requirements quickly throughout their life, making static balancing solutions like wheel weights and balance patches ineffective.
- Mud and snow collection can quickly affect wheel balance. Dyna Beads® will quickly move to rebalance this temporary condition.
- Dyna Beads are the ideal balancing compound for your tires. Easy to install, extremely efficient, won't rust, perfectly round, solid ceramic, and always working to balance your tires every time you drive. If your tire slips on the rim, the beads will adjust and compensate automatically.
