First gen electrical at that.
Okay, I'll go with the Tesla. :unsure:
I have my fingers crossed that I might have found the parasitic draw that keeps draining my battery overnight. Took my LED driving light covers off and noticed that the lights were on, later in the day. I went out to check and the dash fog light indicator light was on, but the switch wasn't pulled out. I pushed it hard a couple of times and it went out. I pulled the relay to be sure and will check it for a couple of days. If that's the issue, I'm guessing it would be a short in the multi-function switch. :unsure:
Made this.
To hold this.
To power these. Thank you to @Zorba for his write up on the speaker install.
(And yes I'm going to rotate the speaker so the Kicker name is horizontal)
With this (Pioneer MVH-MS512BS). 3 weekends later. Not an audio expert by any means but it sounds good to my ears. Just have to tie up the wires a bit and change out the 6ft RCA's for 3 ft's (Why I ordered 6 footers IDK) I will not be doing this again any time soon I did not enjoy doing this at all, but I did learn a lot which is good. But I'm not doing it again, nope, no way.........
Made this.
To hold this.
Reactions: John Cooper
Geez you could paint ya walls with that...wow
Yea. It wasn't the best. Glad to have flushed it. I've been pulling a little trailer a lot so I suspect extra heat has been put on the fluid. Hopefully the bigger breaks help reduce the end heat
33s and a little trailer seem to be a bit much for stock brakes
Reactions: Kiwi TJ
