In and of itself, poly deformation isn't a problem. Where it becomes a problem in a body lift is that each puck may be deforming a different amount (due to varying torque on the body mount bolts, twisting of the frame, flex in the tub, etc) and they no longer support the tub as they should. That leads to broken spot welds and other bad things, as has been experienced by others.
