wonder how many jeeps worth of Johnny joints could you keep quiet for a life time with 35 pounds of grease.
They sell cartridges also just not one at a time via the site, could be worth the call if anyone wants some.
That's great to know!! I'll let y'all know what I find out.
Id try a single tube as long as its not more than the price in my head
So, just because it’s expensive, doesn’t mean it’s going to be good for our application. Has anyone looked into the type of grease it is? What is its base? What are the recommended uses?
https://www.lucasoil.com/pdf/TDS_HD_Mining_Construction_Grease.pdf Maybe we should look at Lucas Mining Grease
We need to experiment with a high performance anti-sieze. If we can find the right metal content, it should provide a decent level of lubricity after the oil carrier has been removed by the cat litter. Nickel is fairly slippery, fairly corrosion resistant, and not expensive.
Or even this stuff if the literature can be believed.
https://www.antiseize.com/anti-seize-special-aluminum-copper-and-graphite-based-anti-seize-compounds
I bought some. I remember talking about this with you a while ago and I need a new jar of anti seize anyway. The graphite content sold me.
The “ingredients” based on the SDS sheet
Is that what we need?
Why do I picture Mike lookin’ like the Tin Man 5 minutes into anti-seizing his johny joints….
You’ve seen that video that bleeping Jeep Matt put out about anti seize haven’t you![]()
I would try to get lube to flow. I drilled my bushings and then lined up the hole with the zerk and was able flow grease. I'm sticking with the silicone base grease for now.
