That scares the beejeebers out of me!
What have I got myself into? At least I’ll have reverse if I can get it to work.
Congratulations! The asuto swap is just a little bit of wiring. No big deal at all, You'll be fine.
I mean it can't be any worse than it is now.
Good luck with the project.
I hate wiring. I’m scared to death. You guys who have done the swap are far more mechanically and electrically knowledgeable than me. Thanks for the vote of confidence.![]()
Start looking at the circuit diagrams now. It takes a bit for them to click, but once they do, you’ll find a whole new level of troubleshooting ability at your finger tips.
Read the first chapter a couple of times, then go look at an easy circuit, like the throttle position sensor.
Here's my list for the NSG-370 to 42rle swap. I've got a few things on the way already, such as the Savvu MUA Auto Transmission Bracket, the shifter Bezel/Indicator, Stalk, and Base Plate. This seems like a big project. Just noticed the OD Switch is not on the list. Of course, there will be other things, like specific bolts and fluids.
Are you adding an aux cooler?
Where’d you scoop up the $106 radiator??
Did you shifter include the shift cable?
Also, I missed the cable bracket on the transmission. Does your transmission come with that?
No, the shifter did not include the cable. I did source it from the same eBay store though. It’s what I have titled the Shift Interlock Cable.
I need to look at the tranny closer to see if it has the bracket. What’s next is just learning the anatomy of the 42rle so I can be conversant with it. The tranny I’ll be picking up is over in Gig Harbor, WA, about 4 1/2 hours away. I’ll pick it up Nov 9, which gives me time to research so I know what I’m looking at and can pick over what’s there. Thanks for the heads up. Another thing on the list.![]()
I’m going to add one. MrBlaine uses the Setrab racing cooler. I don’t think I need that strong a cooler. I can get by with less, so I’m trying to figure that out. Short story, yes.
